FS: 1981 GMT 16750, matte dial, yellow patina.
1981 GMT-MASTER, model 16750, 3075 quick-set date movement, serial number 7.3 million, with original 78360 Oyster bracelet with all 13 links, 580 end links and F clasp code (1981). Comes with a gorgeous, faded black bezel insert and a mint condition "Pepsi" insert. Nothing else is included - only the watch/bracelet as depicted in the photos plus the "Pepsi" insert.
If you've been waiting for a very nice GMT 16750, this could be what you are looking for. The watch is in excellent condition, with a gorgeous dial with a pleasing yellow patina, matching tritium hands and a very nice faded black insert. The case was professionally detailed a couple years ago as well as having the movement serviced. The watch is currently running 2 seconds fast and is well within COSC specifications.
The case and lugs are very nice and full. The inner case lug areas and inner mid-case and case back are from from any signs of corrosion. The serial number and serial number are clearly visible between the lugs.
The bracelet has all its links and has very minimal to no stretch - you be the judge.
The watch is circa 1981, or 1982, depending on which Rolex serial numbers dating chart you choose to use.
PRICE / RETURNS:
- Img_4224.sm.jpg (63.98 KiB) Viewed 13991 times
- Img_4232.sm.jpg (49.29 KiB) Viewed 13991 times
- Img_4229.sm.jpg (58.23 KiB) Viewed 13991 times
- Img_4204.sm.jpg (73.74 KiB) Viewed 13991 times
- Img_4207.sm.jpg (76.49 KiB) Viewed 13991 times
- Img_4213.sm.jpg (72.29 KiB) Viewed 13991 times
- Img_4177.sm.jpg (38.7 KiB) Viewed 13991 times
- Img_4191.sm.jpg (48.86 KiB) Viewed 13991 times
- Img_4198.sm.jpg (59.77 KiB) Viewed 13991 times
- Img_4199.sm.jpg (54.56 KiB) Viewed 13991 times
- Img_4186.sm.jpg (34.87 KiB) Viewed 13991 times
- Img_4178.sm.jpg (43.58 KiB) Viewed 13991 times
- Img_4175.sm.jpg (26.82 KiB) Viewed 13991 times
- Img_4159.sm.jpg (37.33 KiB) Viewed 13991 times
- Img_4162.sm.jpg (35.66 KiB) Viewed 13991 times
- Img_4163.sm.jpg (42.21 KiB) Viewed 13991 times
- Img_4164.sm.jpg (46.64 KiB) Viewed 13991 times
- Img_4165.sm.jpg (79.65 KiB) Viewed 13991 times
- Img_4166.sm.jpg (66.36 KiB) Viewed 13991 times
- Img_5121.serial.sm.jpg (27.18 KiB) Viewed 13991 times
- model.cm.jpg (43.7 KiB) Viewed 13991 times
- Img_4235.sm.jpg (62.83 KiB) Viewed 13991 times
- Img_4238.sm.jpg (44.2 KiB) Viewed 13991 times
- Img_4240.sm.jpg (38.94 KiB) Viewed 13991 times
